gearbox change from 5 speed auto to 6 speed auto
stevesnow
taree
calais ve06c
does anyone know if this can be done or has anyone done a swap from a 2007 5 speed auto box to a later model 6 speed auto box and if so what is involved in the job .people have mention on here to change box to a manual box but i dont really want to do that .thanks steve
vr304
Auckland, New Zealand
2007 ssv manual
I believe there’s a shop called gc cars that do v6 to v8 conversions etc perhaps you could get in contact with them as they’d be able to tell you either way if it’s doable without blowing the budget
Skylarking
124
Downunder
Commodore Motorsport Edition
TLDR, I don’t know if the following will answer your question so best to have a squizzy at the following thread…
https://forums.justcommodores.com.au/threads/ve-5-speed-auto-to-6-speed-auto-conversion.285636/
Also wasn't a 5 speed to 6 speed auto conversion done and discussed in some VZ SS crewman thread (which I can’t find) but the following may also be interesting reads.
Should at least give your some food for thought…
J_D 2.0
Ipswich
2009 VE SSV M6 on LPG and 2022 Kawasaki Z650L
The problem is that the 5L40E box has the transmission control module inside the car (up under the dash IIRC) whereas the 6L50E has the transmission control module inside the transmission itself. In my estimation that is very difficult to overcome without a complete wiring harness from a donor car with a 6 speed auto.
The general consensus seems to be that it would be easier to convert the car to a manual than to convert it from a 5 speed to 6 speed auto., not least because manual conversions have been done before and would require less wiring. I never went ahead with any kind of conversion on my old SV6 and just bought a manual SSV instead! :cool:
VYCommodore76
Blown VY SS Commy
The problem is there are no 5 speeds in good condition left to buy and rebuilding one well is a dark art and more expensive than building 4 speed and 6 speeds.
ah right, that makes more sense
Fu Manchu
Get off your phone when you’re driving.
Western Australia
Kia Sorrento, VZ Crewman, VZ Cross 8, & ya mum.
Correct. It becomes a rabbit hole very quickly.
In regard to the VZ, that is entirely different. It’s far easier. There are adaptor modules that allow it to work.
blackvxss
radelaide
VF SS, VE SS ute, VZ SS crewman, VYSS, VX SS, VTSS
Ive heard people have done the later LFX/LLT motor a 6speed auto conversion to early VE involves and donor car with all the wiring mounts fuel system etc. Very time consuming
