As the other guy said yes, exhaust undone, remove fan pump so as the other guy said rear of engine can drop at the rear, at worst undo engine mounts allow engine to sit on cross member will give another 4-6 inches drop, while lining up box leave in gear so you can turn output shaft to rotate spigot to help line up with splines in clutch. If being real pain use threaded rod about 3 inches longer to thread into block to help keep box lined up, but do NOT use these rods to pull up box if not lined up with clutch will punch guts out of clutch as you tighten up rods. It is always an all dayer or bugger me it drops straight in. :b:
