gearbox not shifting
mackcrackie
redbank plains
vr commodore
hi all
i have a vr and it wont shift into 2nd it just revs if you get up it up to 40kph then back off the gas a bit it will drop into 2nd then its fine PLEASE HELP
EDGE3
NEWCASTLE
1997 VS COMMODORE,1996 GTS-R COMMODORE
Is it an auto or manual?
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
mackcrackie
redbank plains
vr commodore
EDGE3 its a auto
hako when i done the fault code it was all 12's i sat there for awhile and it was still all 12's is there another way to test the throttle position sensor
trav_304
vz ss and vs statesman
Sounds like the tps should put a code up but the only way to tell is by putting a new one in they are expensive try using a mates one first. Ebay ones arent very good either.
trav_304
not sure possibly if its the same engine
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
There is a test for them in the Gregorys manual with a multimeter - someone has one for a VG @ $10 on Ebay ...VG may fit if it has Ecotec...think it does. VN may also fit-----eyeball both or do a search on Google for TPS and see if they have same ID.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
emotec one turns backwards to vn so no good
mackcrackie
redbank plains
vr commodore
vr is not a echotech but i got a tps sensor from a vn and it looks the same so i will try tomorrow and let you all know thanks for the help
