GEARBOX problems help...
vrchicky
huntingdale
Vr berlina
i have got a vr commodore,
and iv had a few troubles,
starting it,
iv had to start it in Neutral,
and it also takes along time to kick into to gears,
its an auto
just wondering what i should do..
cheers
Krisp
34
perth
D22 St-r Navara
why did you buy a stuffed car for. the **** your explaining sounds like the car isnt worth fixing
vrchicky
huntingdale
Vr berlina
It's not to bad,
My boyfriend said it's fixable and won't cost
Much at all.
I also want help with idea to do it up.
Or
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
I'd get your boyfriend onto it - search this forum for similar problems as there are thousands of posts on auto problems. But first of it sounds like the inhibiter switch is maladjusted....also might help to buy a Gregorys workshop manual which will help you a lot. Re doing the VR up, check out the members rides in that section.....also check all the sub-forums on this site. I'm an old bugger and my idea of doing up a VR would be totally different to your ideas.:eek:
vrchicky
huntingdale
Vr berlina
thanks,
hey i like old fashion cars
i actually wanted a Vl rb30 but instead got a vr of course cause of my dad lol
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
Your Dad probably liked the VR over the VL 'cause it's a lot safer vehicle.
Z2TT
VL Commodore
Safer Vehicle hako in what sense?
babe It's kind of hard to diagnose auto gearbox problems without knowing the ins and outs of them.
Check the fluid level on a flat surface while engines running and warmed up.
Auto fluid and filter change is about the most you can do, see if that helps I guess.
Failing that just try pickup a second hand box off a car that was driving well.
Have a look at other peoples threads on here with their pictures to see how they do their cars up,
but yeah my sense of doing cars up especially commodores might differ to everyone on this forum,
Bob Jane cheapo rims and Clubsport kits on Bog stock VR/VS is not my bag.
