Gears crunch shifting 2nd to 3rd
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by jdrVZute, Mar 14, 2011.
  1. jdrVZute
    jdrVZute Donating Member
    Redhead, Newcastle
    Vee Zed Ute
    Hi
    I was wondering why my gears chrunch when I shift 2nd to 3rd gear. Is there a difference in gearbox between a stock V6 and the SV6? like the stock gearbox is rougher? I checked all clutch fluid and **** and that's all sweet. I'm not to crash hot on cars but I'm learning, any tips?
  2. heyitsEnricoPallazzo
    heyitsEnricoPallazzo Big block Alloytec
    VZ A4 Saloon
    You could try bleeding and flushing the clutch system in the first instance.
  3. VzVzVz
    VzVzVz New Member
    Port Melbourne
    VZ S ute
    How many Ks has the car done? The syncro into 3rd might be starting to wear if the clutch is all good. The same happens in our work ute.
  4. jdrVZute
    Redhead, Newcastle
    Vee Zed Ute
    I've got 94,000kms on it
  5. impulsive
    impulsive Alloytec Racing
    Brisbane, QLD
    VZ Alloytec
    The slight difference in the stock v6 and SV6 would be a manual and auto gear box... only a slight difference
  6. VzVzVz
    VzVzVz New Member
    Port Melbourne
    VZ S ute
    Shut up sedan boy, the 175 in the utes ran a 6 spd box.
    If its under 100,000 clicks, then theres no reason for 3rd to be crunching. I'd guess a previous owner (if it's second hand) has been thrashing it and trying to grab 3rd too quick. our work Hilux crunches 5th coz everyone tries to flat change into 5th
  7. Zarconia
    Zarconia Outrageous Fondler
    Rockhampton
    2010 R8 Maloo
    Yeah mine does the same thing, getting it looked at this week im suspecting the synchros but have also been told big end bearing & clutch could also be gone
  8. jdrVZute
    Redhead, Newcastle
    Vee Zed Ute
    yeah i bought it second hand, but the dude was like a 45 yr old man lol, i wouldn't expect him to smash gears? He was a bit gnarly looking so your probably right
  9. impulsive
    Brisbane, QLD
    VZ Alloytec
    LOL, Sedan Boy... To be honest i didnt actually know that...
  10. richardpalinkas
    richardpalinkas Blown Alloytec
    Gold Coast
    Raptor Impulse VZ SV6
    u shoukd stop being so... impuksive lol
  11. ADR 40
    ADR 40 Member
    South Oz
    VZ Lumina..... VEII Equipe Sportswagon
    As mentioned a good clutch fluid flush & bleed is a good start.
    Secondly, change the oil in the gearbox.
    Good chance it's never been changed, if you've got the coin it's not a bad idea to use a fully synthetic oil... does wonders for smoother shifting.
    *Make sure you can get the filler plug undone before draining the box, just recently my mates lad dropped the oil and found the filler plug rounded off... you reckon we had fun!*
    Thirdly, while you're at it.... might as well do your diff, then you know it's all be done.
