I went down today and cleaned everything up a bit, i had a fair bit of dry spray so i sanded that off with some 1500grit, then i roughed the whole car up with some grey scotch bright, did all my final wipe downs and then sprayed some more clear.
Continuously learning! figured out i was moving way to fast with the clear, and got heaps better results by slowing right down. I'm also not very good at spraying the horizontal surfaces and keep getting alot of dry spray, i think that is due to my angle, i have a hunch that i was spraying at like 70 or 80 degrees not 90, ah well, always wiser after the fact.
So as it sits now i should be finished painting with exception of the mirrors and bumpers.
Pics (they are awful photos from the lighting in the booth):
View attachment 174385View attachment 174386
It needs a cut and buff for sure, but i have a good feeling that it is going to look good!
I'll call the windscreen guy tomorrow and aim to get the glass re installed on Friday, hopefully that will be long enough for it to cure. I'll get the heater on and bake it a bit when i can.
