gemini from vn
V
VNBLACKBETTY
Guest
hey guys i want some help here ok now i was thinking of buying a gemmi for racing as they are cheap, manuel of course i own a vn series 2 v6 auto now i heard a rumor that the auto and manuel v6 buicks have different cranks is this true the only reason why im asking is cause ive have done a lil work on the motor as in porting and new pistons any help in that area would be great.
ok second is it hard to convert the motor in there cheers
dodgy
First answer, Yes, however a custom flywheel from CRS or adaptor to suit auto crank. If you go the adaptor you may be able to find a better flywheel, and cheaper to replace. I went the flywheel and had no issues. Marks 4WD also do the adaptors and flywheels.
Second, depends on your skills
