Gen 3 fuel pump for v6 VT
stockyvrcalais
VZ SSZ UTE
hey guys, will a Gen 3 fuel pump from a WH Statesman work in a vt v6?
Nut Kracker
Donating Member
62
Echuca Vic.
VT SS 304ci (195i)
Don't know. Just wondering why you would put a V8 fuel pump on a (supposedly stock?) V6.
I don't think there would be any advantage unless the engine/ECU is modified (injectors, fuel regulator, cam etc.) to accept the extra flow/pressure.
Ian Johnston
Mount Gambier, SA
2015 Subaru Forester, XR6 turbo ute.
If you are talking putting the whole tank unit in, no it wont.
Cashman_309
VTII Calais
While I haven't seen it done, I don't see why it wouldn't.. VT-VZ fuel tank is the same piece irrespective of model (except of course for the extended range tank of course), so a V8 pump should drop in.. As long as it flows the same or better than the standard pump, it should work fine.
Ian Johnston
Mount Gambier, SA
He didnt ask weather it fitted, he asked weather it would work. Yes it will fit, no it wont work. Gen series has pressure regulator valve in the tank unit to maintain 58psi to the fuel system.
stockyvrcalais
VZ SSZ UTE
thanks guys, yeh my mums VT has a dodgy fuel pump (I think), and I have a couple of spare gen3 ones, that's why I was asking, looks like ill have to buy a suitable one for her car.
