GEN 3 radiator
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by blakeoner, Aug 29, 2011.
  1. blakeoner
    blakeoner New Member
    perth
    VZ commodore
    hi all
    just wondering is a LS1 radiator will fit into my vz v6?
    and if so do you reckon it will do anything in performance wise
    thanks
  2. Munz
    Munz Right Foot Action
    Brisbane NTH
    VZ Calais LS1 / VL RB30e daily
  3. azazeldeath
    azazeldeath Donating Member
    Welshpool Vic
    VK Holden Commodore Wagon w/3.8L Buick
    He may be asking a serious question you know. To answer your question. Yes it should fit, you need to remember that Holden is very smart and lazy at the same time, they mass produce the cars and leave the engine fitting as an afterthought. Meaning you can easily put an LS series engine into a car that came factory with the Alloytec.
    So yes, the LS radiator should fit into the engine bay of the V6 car, some slight modification may be required, namely around the hose area.
    As for performance, I cant say with a 100% certainty but I would say it would give no performance gain, youd be lucky to see a difference in the temperature it runs at.
  4. Munz
    Brisbane NTH
    so so serious...its a radiator
  5. richardpalinkas
    richardpalinkas Blown Alloytec
    Gold Coast
    Raptor Impulse VZ SV6
    wont do jack, the standard radiator does its job at keeping the engine at optimum temperature. having the engine at normal operating temperature is where the power is, not whether the engine is cold or not
  6. blakeoner
    perth
    VZ commodore
