Gen3 dyno question
lsx427
MELB
www.seperformance.com.au
VY MALOO
is it just me but 1100nm torque seems a bit much for this combo usually its like 650-700nm
yes-being in a lower gear will cause that-
unless the engine has got some big cubes behind it,n20 or turbo/blower.. or some decent rpms and a big ass stick..... i find it pretty hard-
their should be 5-10 rwkw more gain in it being in a 1.1 ratio gear.
Gen3Jonesy
VTII SS Gen3
Its just to hard to fake numbers on dynamic test systems-you will get caught out-
i feel on the dynamic test systems the only way you could cheat would be to increase the ramp rate but the afr ratio will be way off-
the name of the game is to get the afr's vs the temps vs the spark and so on and on, dial in spot on-so the operator is really hurting his education and his work if you ask me.
i own a dynamic test systems and i am in melb if you want to put your mind to rest-
i like to do everything in 1 to 1-sometimes its gets a bit tricky as other cars tend to kick down like some fords i done-
the way around it is to slowly feed the pedal in and a reach a speed that the trans cant kick down.....
with a auto on the dyno you need to get stuck in it asap or else it will cook the trans-
i seen to many auto cars cook on the dyno due to the temps being threw the roof-
wether a trans is good or bad-by running high temp's will destroy both-
the dynamic systems reads low from what i had come here-
5-10 rwkw dd
5-15 rwkw mainline
10-25 rwkw from a dynologic-
never had a dyno pak to compare...........
but numbers are numbers at the end of the day-
? for ya-does it go like you wanted it to go
does it feel like its got 270-280 rwkw?
I did a lot of research before buying this dyno vs the others on the market.
If you have any more questions feel free to ask-
Hope that helps.
Cheers for the help there mate!
It has definatly had an increase in power, I cannot question that :) The issue is that the package is sold in kW values and I want every last kW possibe for the (quite large) outlay... There are also a few other issues that have risen up since and I'm just feeling slightly stooged...
Where in melbourne are you and what do you charge for a dyno run?
GMMAD
Nowra
3.8L GT35 4runner/VK calais
Hey guys!
I've recently had a fair bit of work done on my VTII SS gen3...
Heads
Cam 224/234
OTRCAI
Highflow Cats
Springs + Pushrods
Extractors + Twin 3 inch system
VX Manifold + 80mm throttle body
Mafless tune + rev limiter up 500rpm
3000rpm converter
And a rebuilt t700 with stage 2 shift kit and cooling system going in tomorrow.
Diff ratio's are still standard.
Now with that all out of the way... Onto the question...
On the dyno she made: (@ Wheels)
271.5 kW @ 5502rpm
1186.1 Nm @4191rpm
BUT....
My understanding of a dyno pull is that it should be done in 3rd gear, as close to 1-1 ratio as possible(I believe 3rd in the T700 is exactly 1-1?) ... The pulls that produced those figures were done in 2nd gear (1.63 - 1 ratio apparently)...
How will this effect the numbers? Is it what you would call a *True* reading?
Would I then be wrong to say "My car has 271.5kW @ the wheels"??
I've an ever growing mistrust of my mechanic, even these figures aren't up to what was promised before the mighty dollar was handed over... I would appreciate any answers you guys may have...
Cheers!
for a head and cam combo that figure is a bit low
and it is 271.5 kW @ 5502rpm that cam should be making peak power at near 7k
and 1100nm is way to high should be around 700
and yes dyno should be done in 3 gear
vtssgrunt
vt
dyno numbers
the dts dyno reads slightly lower than most dyno's,partly due to the 4 rollers turning all the time,even when the wheels lift onto the front rollers.
(It is more accurate than others,hey)
This means the numbers dont change for the better as some dyno's do!
Try contacting the workshop that did your dyno and engine work,as the dyno may have been done in 2nd gear because of the rpm versus speed .The dts dyno has a top speed of only 198kmh and in 3rd gear 1.0 :1 ratio it will max out with speed.This looks as to what has happened with you.
If the car feels like a weapon and it is heaps faster then maybe it is 270kw wheels,it sounds like you are confused abit and be causious listening to too many forum experts.
Try the normal approach an go back to the workshop,discuss your concerns and they will help,there the experts.Expecially if it has the power and parts used,it seems normal for a 5.7 with 250,ooo km ? with cam and heads to do this.
As they say some dynos may have had 285kw wheels ?
Also there was a post saying you can do 7000 rpm?,with a std vx manifold
(i don't thinkso?
all the best.
GMMAD
Nowra
(i don't thinkso?
all the best.
the standard LS6 can handle 7000rpm
Baldric
The BOSS
44
VE GTS M6
i reckon yours can handle 7500 launches steve :D
minux
2017 SSV Redline
Why do people get caught up in ****ing dyno figures? Workshops are making shitloads of money off it because people like to brag about inaccurate dyno readings.
Should be based on what the potential time it can do down the 1/4.
Baldric
The BOSS
44
VE GTS M6
because they are a good reference tool to get a average reading
Gen3Jonesy
VTII SS Gen3
(i don't thinkso?
all the best.
Anyone notice anything funny with this post by VTSSGRUNT?
Seems there is at least one detail about the car in their post that was not included in any of my post's...
Obviously this is the workshop in question posting :yeah:
No surprise there, I'm well aware that they check/participate in forums... Wierd that it took so long though...
And for the record the "Normal approach" has already been taken and the car is booked in. With any luck I'll pick the car up next week with the problems solved and this chapter can be closed. :thumbsup:
Stay tuned for the next exciting installment...
ScoHar
Jizz in my pants
CHCH, NZ
VS Senator
Bahaha, interesting although it is good to hear both side of the story.
