LS1SS
- Jun 25, 2017
- 228
- 164
- 43
- Age
- 70
- Location
- Milperra
- VF Redline.1970 Dodge R/T Challenger 440 six pack.
As my afore mentioned post,these are the parts and cost trade you need to fit the trans cooler to which I’ve just done,yes expensive but factory fit and look,easy to fit,you just undo top radiator bolts lean it back and slip pre assembled cooler down the front,bolt to top of radiator,remove stone guard from under radiator to bolt up trans cooler to condenser,it bolts up perfect,took me about an hour less jacking car up to top up trans oil,don’t buy Holden bolts and clips (cost heaps) scrounge around shed for them,this unit fits VEs and VFs even with OTRs,you can’t use the VE factory one with OTRs as they are huge,to undo oil lines you get a sharp tool,push back the black collar,pry out spring clip pull lines apart to hook back up just push together.
