gettin a jump off the line
benjamino
needing some more undies
The Sticks, WA
VX SS 6spd + 7psi
hey guys,
got my 6spd manual vx ss,
and i seem to get smoked off the line by gen3autos, cause they can just sit on the brake and just go flat out at the change,
but ive gotta do the whole clutch thing..(ohh here come the u cant drive for **** jokes)haha
but anyone have a good recipe for gettin off the line super quick in a manual?
would it be trac off, sit the clutch on friction point with no accel then accel at green?
or just rev and dump the clutch quick?(or slow) with trac off? or on?
just seeing how other manual drivers get a good leap off the line....
cheers guys
Morton
For external use only
Fairstar the Funship
For my car, I rev to about 3500rpm, then let the clutch halfway into the friction point and floor it 3/4. Adjust throttle as needed, and ease out of the clutch altogether as the wheels stop spinning.
H1GHROLLR
CHEMICALLY SUPERCHARGED
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
get 3.9 gears and a textralia clutch and dump it at what ever revs you wont
betts
vxc
b
You need to experiment a bit and find out what is the best rpm to hold your engine at before you start releasing the clutch, what morton said is pretty good. I have a mate with an xr6t, and has worked out that his optimum revs are at 3500, and he can pretty much dump the clutch, get mimum wheelspin, and it rockets off the line, you just need a bit of experimentation to find out what is best for you.
Reaper
Tells it like it is.
RG Z71 Colorado, 120 Prado , VDJ200, Vantage
It's all practice and technique. You do have a bit of a choice though - get bogged down (slow) or slip the clutch a bit for the first little way for the fastest launch.
Reaper
Nanos
Not a Mod
Frankston
VXII LS1 Berlina Wagon
a manual should smoke a auto of the line no problems. i know as i have a ls1 auto.
if you are getting too much wheel spind try some low revs, let it bog down a little or release the clutch a bit slower. once you are away you will catch a auto. the auto's are very sluggish down low unless they have a stally(like me). lol
FusionX
Western Aus.
Balance of clutch, accelerator and handbrake if you have the ability to multi-task. If not leave the handbrake out of it (have seen people do this, forget the handbrake and bake the handbrake pads).
CANYONERO
Likes Cheese...
Country SA
V8 6spd wif MOMO leavaa.
ls1 bout 3000 seems about the best amount of revs.
the collector
the collector
adelaide
rodeo dual cab
drag
focus on what youre doing.
practice and practice
cheers
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
are you talking on the road or the strip.on the strip you want to be going before the green.
