Im getting a service in 2 weeks. Just found out one of my bearings is making a noise so it will need to be replaced. And my computer is out i think im getting 15.5l 100km :s Oh and sounds like the front shock is gone. Just wondering how much a shock and bearing are these days. Rough idea
Front or rear bearing? Rears are not that easy to replace (I suspect you need some form of press or puller) and the fronts, whilst reasonably simple to remove, would be pretty expensive, as they are a sealed unit, comprising the bearing, hub and "spindle" and the anti-lock braking ring. Big bucks at either end - how's your warranty?
I meant engine bearing my bad sorry. Thats to do with the main drive belt And front shocks need to be replaced.
the pulley bearings, that the serpentine belt runs on, you will need struts (different form of a shock, houses the spring aswell) for the front
