Getting code 25 VP V8
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by dans_vz, May 30, 2011.
  1. dans_vz
    dans_vz Active Member
    Swan Hill
    MY16 VFII SSV Redline Manual & 05 VZ Calais daily
    Hi guys im getting the engine light on all the time when the car is running, I checked the code and its 'code 25 - Mass Air Temp Sensor (MAT) - Voltage Too Low'
    I have now replaced the MAT sensor and reset the computer, the engine light didnt appear for about 5 mins of driving but now it has come back on again and showing code 25. What else could be wrong when I have put a brand new sensor in?
  2. redvpsenator
    redvpsenator Donating Member
    vp senator & VS Ute
    Cheers, Did you check the vacuum line to see if it is cracked or broken?
  3. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    MAT sensor = (Manifold Air Temp) sensor..Id check the wiring to the MAT sensor,if it all looks ok,then clear the error code again by removing the neg battery terminal for a minute or two,then if the code comes back again after clearing the code and driving the vehicle, replace the MAT sensor as it might be faulty..Ive found that a lot of cheap brand sensors are rubbish and its always best to use genuine holden sensors..The MAT sensor does not have a vacuum hose connected to it..
  4. redvpsenator
    vp senator & VS Ute
    LOL, My mistake [old timers?] got mixed with the MAP problem I had with the V8. cheers
