Getting cruise control cable off bracket
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by AirStrike, Mar 2, 2007.
  1. AirStrike
    91' VN SS
    Ok, have started stripping the engine bay to tidy some **** up and have hit a snag! ILL BE STUFFED IF I CAN GET THE CRUISE CONTROL CABLE OFF THE BRACKET!!
    It appears that there are two tabs that have to be depressed and then the main plastic body slid out of the bracket, but I can seem to get the tabs in enough. Does any one know if i'm doing it right, or have any tips?
    Cheers Dave
  2. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    Tried some lube? The 2 tages are the only bit holding it in. Small ish flat blade screw driver did the trick for me.
  3. CSL
    CSL Member
    missus (in more ways than one)
    just take out the 2 10m bolts and lay it on the engine bay, if not just take it out with the cruise control,, but if you really need to paint the bracket get a big arse screwdriver and pop it
  4. AirStrike
    91' VN SS
    Yeah it's getting powdercoated. I just waited till someone else was home, its much easier to get out with 4 hands:p
