getting ####ed off at shuddering/vibratin in in steering wheel!!!!
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jas98, Apr 23, 2012.
  1. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    hi, as some know i posted a while back about a vibration in my vs commodore v6 sedan
    anyway after cheacking everything, changeing the rear trans mount for good measures i have not seeen or fixed whats cuseing teh problem
    now this has been happening for quite some time, in that time i have changed :
    tir rod ends
    rack (recoed)
    ball joints
    every bush u name it its been changed
    springs
    shocks/struts
    strut tops and bearings
    engin mounts (although a while ago and this wast happening then nor after i changed them (could be them but they look fine)
    etc!!!!
    oh also everything electric that could cause it (spark plugs sensors etc leads coils)
    anyway prolem is when acellerating theres a wobble/vibration in steering wheel and very slightly in the car like at front end like engin wobbleing (but mounts look good) BUT when accelerating HARD there no vibration its as smooth as anything,
    cruiseing at a constant speed then acceleratng (lightly) to keep that speed you fel it straight away
    also at 110 and keeping that speed its the worst!! steering wheel wobbles side to side etc however it does not always wobble vibrate etc
    all tyres are fine i know what to look for in these cases but its got me stumped!!!
    also could a bent rear axel cuase this? as mines a live axel however it has no reason to be bent
    the car was hit on the left side a while back where the fron and rear doors meet but it was fixed (wasnt bad but was written ff as it cost too much as compared to how much the car is worth or someting) but it was fine after that
    thanks
  2. jas98
    jas98 Active Member
    maryborough QLD
    also all bolts, wheels tail shaft everything is tight
    can adjusting the rack help? it was a reco one but aint there an adjustment? like i think rack pad adjustment of somthing, can a tyre place do this?
  3. Linzi
    Linzi New Member
    Crystal Brook
    VS Acclaim
    Get a wheel alignment and balance?
  4. ari666
  5. VT_SS
    VT_SS -
    EVIL304
    Harmonic balancer maybe or a long shot at warped rotors.
  6. jas98
    jas98 Active Member
    maryborough QLD
    thaks for replys, as to wheel alighnment/balance it did it after 2 balances from differnet shops, and wheel alighnments (had 2 as 1 was when i got rack done and other was gerneral 6 monthly etc)
    as for it being lowered its only on kings lows, it shouldnt be that...could it?
    also how could wheel alighment make it worsewhen accelerating? and balance?
    cheers
  7. jas98
    jas98 Active Member
    maryborough QLD
    double post!!!!!!!!!
  8. jas98
    jas98 Active Member
    maryborough QLD
    harmonic balancer replaced, forgot to mention same before and after
    also warped rotors, could be as i do get a bunny hop feeling when brakeing, will check that and replace with some spares i have, i have really replaced a hell of allot of **** on this car for lerning experiances and for fun lol
    cheers
  9. Chrispy
    Chrispy Member
    VZ Calais, 2015 Daytona 675R
    Center bearing and Unis?
  10. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    I seem to remember reading somewhere that when you lower a car with a 2 piece prop shaft, you should also alter the position of the centre bearing so as to return the prop shaft line to that it was before lowering. I know on Jaguars with the 2 piece tailshaft, you make tool (simply 1.5m of 3X2 with 4 large nails embedded) that you hold against the prop shafts and then raise/lower the centre bearing so the shafts are in a straight line. I also know that with Jags this adjustment is not always critical with some cars needing it and others that don't need adjusting. The fact that yours has had a side impact may have made this more critical. It's simple to do and requires only a length of 3X2 and 4 nails OR you possibly could use a length of cord streched tightly from the gearbox to the diff and then take measurements off that.
  11. jas98
    jas98 Active Member
    maryborough QLD
    ive checked and checked and they seem fine however im about to buy some new unis and bearing to be sure but i dont think its that as they look and feel and check out fine
    hmm this is good info, so the shaft should be stright when sitting on ground? i e car on ground?
    dont the shaft move when driving anyway?
    cheers
  12. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    The rear half of the shaft moves up and down as the rear axle moves but it will always return to the same position when the axle stops moving (over bumps)....however if the car is lowered, the normal position is different. As mentioned before, I've seen this subject discussed on this forum with regards to lowering....plus the prang! However, did a quick search and found this which deals with the centre bearing alignment - it's from a Volvo site...they use the same style tailshafts.
    Before you conclude this is the problem, make sure your engine and transmission mounts are in good shape. The level of driveshaft vibration can be reduced by changing the vertical position of the center support bearing. The support bearing is bolted to a bracket, which in turn is bolted to the underside of the car body. Adding shims or washers between the car body floor and bracket will shift the bearing down. Adding shims inside the bracket between the bracket and support bearing will shift the bearing up. Best results differ from car to car. Start with a change of 6mm (1/4") upwards. If results are not acceptable, try positions from 5mm (3/16") downwards to 12mm (1/2") upwards from the original position. Note that clearance between drive shaft and fuel lines must be at least 20mm, and between drive shaft and the fuel tank at least 16mm. Shimming upwards should not exceed 12mm (1/2") and after re-positioning the center support bearing housing should not contact the floor pan.
    The site is: Driveshaft, Rear AxleDriveline, Rear Axle
    I'll also see if I can dig up the stuff on my old Jaguar.
  13. IBLOWN
    IBLOWN Well-Known Member
    VS V6 TT/'13 VF Senator/'11 WM CapriceV/Hayabusa
    Are you running stock brakes? Has it got aftermarked wheels? Have you got shims in the wheel spiggot bores?
  14. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    Found some info which should make sense from JagLovers archives:
    When I first bought my 77 XJ12L back in '85 it had this strange shudder in the driveline, (or 'judder' as the Haynes manual calls it), whichmeant that the two part driveshaft with a centre support bearing was
    mis-aligned. It is adjusted by sliding the centre support bearing side to side. According to Haynes there is a 'special tool' for aligning driveshafts in series 1 and 2 Jags which looks prepostrous and of course,
    un-obtainable. My (very good) Jag specialist mechanic had never heard of this tool and tried to align the shafts by trial and error... up on the hoist, loosen the four bolts and their rubber mounting washers, move
    the bearing and its bracket, road test, then back on the hoist again...to no avail. In desperation, I went to a (Gulp!) Jaguar Dealer who talked me into replacing a perfectly seviceable centre bearing and
    new rubber washers on the bearing mounting bracket, assuming he would align the shaft as a matter of course,(given the high hourly rate he charged and all that plush carpeting in his waiting room,) but it STILL
    shuddered on take off...although it was smooth as silk at any higher speed. So one day while I was replacing the rear transmission coil spring,I used my own brain instead of Haynes's or the Dealer's or the Jag
    specialist's and came up with this solution: Take a four foot carpenter's level (as straight and rigid as you will get), and 4 six inch lengths of 3/4" wood dowel, duct-taped to the level at four places, the spacing of which correspond to each end of the two driveshaft tubes. Insert this 'gauge' up into the holes in the driveline shield so that the sides of all four dowels just touch the sides of the driveshaft tubes, or move the bearing until they do, and you are aligned, at least laterally. The vertical alignment seem to be set at the factory, thus the importance of new rubber washers and the transmission rear mount coil spring.
    Smooth as silk ever since...as a Jaguar should be.
  15. strgas
    strgas GRA = REAL HP
    Check the c angle at the diff nose and tail shaft alignemnt side to side do you have an adjustable panhard rod ? the centre bearing support bracket should have the spacers between the bracket and the bearing collar not the bracket and the body which will raise the tail shaft up to bring it into aligment with the lowered suspenion
