ghost lights ????
surfindude
hothouse green
37
VY S pack s1
hi
i have a vy commo and my lights playing tricks on me and im not sure y
my problem is that when i turn them on to low beam they work correctly but if i turn high beam on the fog lights also come on and the light on the drivers side go very dull. if i turn high beam off then they go back to working right, but if i turn my fog lights on when on low beam the high beam comes on and again the driver side lights go dull????
so i think the problem is in the in the hig beam or fog light switch.
the fog lights are wired up correctly as they have been working correctly for years.
this all started to happen just after i changed my globes to white ones.
so can someone plz help!!!
this might be one for the god "preddy"
thanks all and hope u can help me
nmj
North Subs Perth
Vx Acclaim S2
thatsa tuffy... u tried a auto electrician... but they will charge like a wounded bull..
hope ya figure it out mate
naf33n
go
The Shire
Supercharged VU SS
put the old globes back in and see if it still does it. that will help narrow down the problem
surfindude
hothouse green
37
VY S pack s1
did that but with no luck
but when i did change them over u noticed that one of the wires had been squashed and wire was showing so i think it might have shorted out some where maybe but everything still works i think it is earthing somewhere it shouldnt be maybe the switch.
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
check the fuses, one side will be blown, the problem will be in one of the fog lights, the bulb wiring is shorting inside the case.
Rob
surfindude
hothouse green
37
VY S pack s1
IT WORKED
thanks mate
i dont no y i didnt do that b4. because they were all working i thought that all the fuses must have being right.
thanks again mate
