Going crazy
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Agey20psi, Sep 15, 2019.
  1. Agey20psi
    Agey20psi New Member
    Vx commodore l67 supercharged v6
    hey i own a Vx v6 supercharger it keeps stalling cutting in and out while I drive um I have changed inlet manifold/supercharger gaskets,new crank angle sensor,new idle sensor,new throttle position sensor,new fuel pump,new fuel pump module,checked all vacuum hoses now I’m loosing my mind the car won’t even turn over fuel pump not coming on changed ecu bcm (paired) checked relays and fuses the crazy thing is I can get it to turn over if I pull relay out and hot wire fuel pump dose the same
  2. VT2Commie
    VT2Commie Active Member
    WA
    VT2 Clubsport R8
    Have you checked the wiring? Diagnostics?
  3. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    You will have a new car soon, all you need now is 02 sensors, dfi, coils, plugs and leads, maf fuel pressure regulator. If that fails bcm and ecu. Check your dfi wire harness and earth leads battery terminals, clean and check fuse box and relays.
  4. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
  5. Trevor loves holden.
    vs commodore
    Get the plug checked that goes into the DFI plate. Others had the same issue on and off for weeks. Replaced Crank sensor, DFI plate, coils and that didn't help. Read somewhere that the plug can sometimes have a pin which is corroded or slightly bent. Lo and behold when they checked It they found it had a slightly bent pin(very hard to notice). push the pin out and replaced it they haven't had a problem since :) Best to get and auto electrician to do it.
  6. KustomKulture62
    KustomKulture62 Active Member
    Queensland
    2013 Specialized Hardrock Sports Disc 29er
    What are the codes saying?
  7. Agey20psi
    Wat do u mean fault codes,every time I start it the trac off light comes and so I push trac button but nothing changes
  8. Agey20psi
  9. _R_J_K_
    Zenki S14
    What kind of spark plugs are in it? Did you up the boost at all?
    When you say cutting in and out do you mean like it's missing or turning on and off completely?
  10. Agey20psi
    Hey um yeh I did up the boost only for a day or two n I mean on idle it will will rev up and down then stall and it’s weird sometimes the trac off light comes on with out me turning it off and then I catch switch it on or off n spark plugs are platinum
  11. Trevor loves holden.
    vs commodore
    Alternator not over charging is it? Checked your DFI plug yet? Maybe a crook CAS not the first time a new one failed. Have you checked your injectors for constant power and ohms to see all within range with each other? Any Christmas light at night time from plug leads? Are your coils good?
  12. _R_J_K_
    Zenki S14
    Got a part number on those plugs?
  13. Agey20psi
    When u say alternator over charging would that make the computer (ecu) run hot
  14. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    What gaps you running? SC needs high voltage coils or smaller gaps than an Eco.
  15. Agey20psi
    Bosch R6 HR8DPP30V
  16. Agey20psi
    Wat size gaps? and I did order s/c coils but whose to say that’s wat I got thanks man
  17. losh1971
    North Tas
    VR Ute V6
    Plug gaps
  18. Agey20psi
    Lol yeh wat size should the plug gap b then
  19. losh1971
    North Tas
    VR Ute V6
    1.3mm.
  20. losh1971
    North Tas
    VR Ute V6
    If the gaps are incorrect don't try and regap them now they have been used in the engine, grab a new set of plugs. Gapping used plugs is fraught with danger, the ground straps can snap and destroy a piston.
