good 6x9s
AnDReII
я σ м µ и s k ι
VZ CALAIS
i need a good set of 6x9s that will take alot of beating,
ive had a set of jl audios that the tweeters blew up on me and a set of kickers that did the same thing,
what do you guys think would be a good option.. ill pay up to around the $350 mark
sweefu
VY Berlina V6 / R31 Skyline
What were you running the previous speakers off? I'd find the cause of your problem before buying more, speakers should not blow up.
AnDReII
я σ м µ и s k ι
VZ CALAIS
ummmm alpine vpower 600watt 4 channel, i think its 600 if not then its 500w,
its funny coz my fronts blew aswell... its so bad i have no highs at all... got mids and lows but no tweeters-.-
i gota get it all retuuned but i guess i still need speakers and for the front im probably gona get the alpine spx17 pro but not sure about the back as of yet, thats why im asking for help:)
juzzyx
04 VY Wagon
If its 6x9s your after, look no further than the Vibe BlackDeath series. These woopers have a 2.5 inch voice coil... 200rms each.
VIBE Audio BlackDeath BDQB69 Rectangular 6x9 3-way Car Speakers (BD-QB69)
6" x 9" 3-way Triaxial Black Death Rectangular Speakers
Power Handling
Peak: 600 watts per set / 300 watts each side
RMS: 200 watts per set / 100 watts each side
Absorbing polypropylene woofer cone for enhanced depth and clarity of bass
Butyl rubber surrounds
2" Aluminum midrange driver
1" Titanium dome swivel tweeter
Rubber gasket ensures a perfect seal
Cast aluminum angular torsion chassis
Protective removable ABS grilles
Single spider design provides control and stability
Single 40 oz Ferrite magnet
Rubber magnet boot protects the magnet and can be removed for shallower installation depth
Separate passive crossover network
Screw down terminals
2-1/2" Voice coil
Sensitivity: 93 dB
Frequency Response: 30-25,000 Hz
Impedance: 4 ohm
Mounting Depth: 3-15/16"
Mounting Diameter: 6-3/4" x 8-3/4"
AnDReII
я σ м µ и s k ι
VZ CALAIS
hey juzzyx how would i mount these in a parcel shelf tho?
Zend3r
Melbourne, VIC
VZ Berlina
Mounting holes should be in the same place, will just need to plug the gaps. I've never had any personal experience with these though, so I could well be wrong.
AmmoJammo
Adelaide, Australia
VL Wagon
they really aren't going to fit into an oval hole...
juzzyx
04 VY Wagon
I think the VZ Calais parcel shelf had 6x9's, see if you can get one from the wreckers
I know you can get an adapter for them in a VX commodore, they just go right in.
juzzyx
04 VY Wagon
Check out this thread.
KCPwns wrote:
"Youll have to cut the carpet/plastic...your Parcel shelf should already have a groove to follow.
And the metal underneath should just pop out use a hammer or fist lol...
Although I seen your other thread about subs, if you are going to get subs you
wont need 6x9's in ya shelf mate, some 2 ways in the rear doors will suffice.
although I would still put the holes in your shelf so the subs can port straight into the cabin "
http://forums.justcommodores.com.au/vy-holden-commodore-2002-2004/172144-6x9s-vy-parcel-shelf.html
Grilles
Shop - Car Audio Bargains
sxchsv
2004 VY S2 SV8 5.7
Vibe Speakers
Hey Guys, I was just looking @ the Vibe Splits, I like what I see..
Has anyone seen those over here or heard them Running?
My Vy SV8 had no speakers in parcel shelf, so cut the trim made some nice MDF 6x9 templates and just cut enough room for 5.1/4" for the rears.
Im not a fan of Back Door Speakers.
Brendon
