ok, a couple of questions, if ya dont mind answering one or even all if ya can. in my vt some idiot put the steering wheel back on wonky, now i have to take it off and put it back on straight. whats the steps in taking it off and putting it back on? ....also i need my air-con fixed, ive had it regassed and it leaked out again, but i think i need to fix the leaks or something along them lines, anybody know the best place to go for it? or holdens is the way to go? ..and finally, is the best place to go for the altezza monaro headlights and taillights on ebay? cheers
where are you located? i can recomend one good place in vic that i always use for all my mechanical work edit: sorry just realised your in sa maybe gilbert motors in strathalbyn if thats not too far away?
Well for the steering wheel, just disconnect the battery and the airbag fuse. Remove the screws holding on the airbag pad from behind. Then you'll need a puller to remove the wheel from the spline. And with those altezza lights just search ebay there everywhere
id say its probly like that from alignment.. not unusual for places to just pull one wheel straight to the other.. without checking the position of the wheel resulting it straight wheels when steering wheel is turned and do you know where the a/c is leaking from?
A common place for an A/C leak is the seal where the hoses connect to the compressor, and they're not too expensive either.
For the steering wheel, you need to disconnect the battery for 30 seconds to disarm the Airbag, then you need to undo the star screws on the back if the wheel, disconned the airbag wires, then undo the bolt to get the steering wheel off. realign it and slide it back over the spline. You don't need a puller for the VT steering wheels. Then just reconnect the airbag wires, put the airbag back on and reconnect your battery.
