H
harrop.senator
Guest
Hey guys the ls is apart at the moment and I'm wondering just how much I'll benefit from dropping more money on a different camshaft.
It's currently running an isky 220/230 but it only has .530"/.550" of lift.
Unsure if the heads have been shaved haven't cc'ed them but the cold cranking pressure is absolutely where it should be with where the cam was dialled in. 180-182 across all 8 cylinders so the valve intervals are obviously a good fit for the motor.
But the lifts a little lame! I'm unsure on whether I should spend the money on a larger stick and some new springs or if it won't reallyyyyyy be worth it.
I'm wondering about possibly just retarding it 2-4 degrees to push the power band up and sneak a couple more horses.
It went 350atwhp with a bad tune and a maf an airbox. Seeing as I'm having the tune touched up anyway another cam has go me curious.
I've got a 3200-3500 off shelf stall that's not fitted so no idea where shell actually flash it was just a good deal and with the new lock up converter tech I don't mind "over stalled cars" as in my opinion you don't notice until you jam the pedal. It's got a fat torque curve supposedly pulls 2-6 bit really comes alive at 3200.
Trouble is it falls of 6k that's not advertised that's how it drove before pull down and I know I'll sneak some more horses pushing the revs up further.
Long story short without any other mods but supporting springs and tune how much room for improvement do I really have with tri y pacemakers, 100 cell high flows and twin 2.5" exhaust and 3.46 final drive InIa full weight wh caprice. I don't know if dropping a grand for another 30 rwhp is worth my money but for another 50-60 it would be.
