good morning everybody, I bed for soem help with my WM!
MarekPoland
54
Krakow
2009 Chevrolet Caprice Royale WM V8
Good morning, 'I am new here, writing from Poland..I just bought Chevrolet Caprice Royale 2009, V8 I read it is the same as Holden Statesman WM and I have big problem ,as it is one car in Poland like this...nobody has spare parts and I need shock abosorbers, rear brake pads, lower control arms fron as well as data for wheels aligment , also would need some plastics like new sunvisors.
CAn you let me know any shop than can buy via internet and ship to Poland? The car was manufactured in Austrlia for Arab market, it was brought to Poland from Dubai last year..
thank you and I appreciate any HELp
Marek
syked
Donating Member
2011 WM Caprice
Welcome and hello from Australia.
If you pass on your VIN I'll see if I can get list of part numbers and you can find some online shops closer to you otherwise shipping from Australia will be expensive especially because the items are quite heavy.
VFSV6FORME
74
WN Caprice V 6.0L, VE Anniversity V6 Series 1
If you pass on your VIN I'll see I can get list of parts numbers and you can find some online shops closer to you otherwise shipping from Australia will be expensive especially because the items are quite heavy.
Yes I say so. Most Ebay.com.au wont ship to Poland
MarekPoland
54
Krakow
Hello from Poland.
You are greatJthanks.
Here in Poland I can only give to dealers parts numer in this scheme: MOOG , MEVOTECH lub RAYBESTOS otherwise thay know nothing..
Or OE number can help.
I need lower control arm right front, rear break pads and rear shock absorbers Monroe I made a photo what now I have on my car..( attached) and I have an oil leak from engine top, so I need gaskets, and also gasket between engine and automatic transmission.
I also would need some plastisc but I am not sure if thea are available new, maybe you can advice where I can find second hand? Like sun visors with assebly ( it is broken).
The rest is OK.
VIN 6G1MZ55H79L158507
Thank you for any help, God bless You.
syked
Donating Member
2011 WM Caprice
These are all GM OE parts
Complete Front control arm - 92250641 (L and R)
Rubber bush for control arm - 92159305 (L and R)
Complete Front Caster / Radius Arm right - 92253412
Complete Front Caster / Radius Arm left - 92253411
Rubber bush for caster arm - 92250639 (L & R)
If you wanted upgraded bushes for control arms or caster arms or even upgraded complete control arms or caster arms, check out SuperPro europe
Rear brake shoes (for handbrake) - 92196003 (L&R)
Rear brake pads - 92265457 (Set for 2 wheels)
Rear Disc Rotor - 92265227 (L & R)
Rear Shocks - use the one in the photo you sent
or 92269784 - (L & R)
You need to be bit more specific about the oil leaks.
Top rocker cover gaskets - 12637683 (L&R)
Sunvisor - your colour will matter but I can't see which colour is for your VIN as it returns no results.
92184501 - L side Neutral colour
92184507 - L side Onyx Colour
92184511 - R side Neutral colour
92184510 - R side Onyx colour
