Good ole radiator
Schwarz
50
Auckland NZ
VT 2000
Gents
My vt gets up to temp pretty quick and stays between the 2 line and half way which I read is normal on here it's not even a 5 to 10 min drive
My fan never comes on at all but why would it? if it wasnt getting hot I have turned it off and did the mode check nd reads 91d
My heater core is leaking nd I'm due to either bypass or put some risoline nd fix it in the summer properly
I still need to re gas the AC has the valve in the port was buggered so the ac fan doesn't kick in either
Cheers all
Trevor loves holden.
vs commodore
low speed fan wont come on till 104deg then switch off at 99deg. If your A/C ran out of gas and got moisture in then you should replace the drier, Heater core your better off replacing it band-aid fixers never last long, its a bugger of a thing to replace.
High speed on 112 off 108deg.
vr304
Auckland, New Zealand
2007 ssv manual
I wouldn’t go putting any of that stop leak crap in your radiator mate it will gunk up the cooling system better just to bypass it temporarily as you said or fix it and be done
