sire01TMK said:I have a VS & I mounted my 2 ALPINE amps on a piece of 16mm mdf on the axle hump behind the back seats. I attached 2 90 degree angles to the mdf & then attached it to the frame behind the back seats with a few screws, PIECE OF CAKE! :thumbsup:
Crimmo said:Got any pics? I've got a VS and was thinking about doing the exact same thing.
deserthead said:I've got a VX and b4 the gas conversion I mounted my amps (3 of em) under the parcel shelf. There is heaps of room under there, and you dont even notice them when the boot is open.
As far as mounting goes, its all circuit board (electronic/solid state)stuff inside, mounting it vertical aint guna hurt it.
Any other questions bout running cables etc, shoot.
Cheers, Keegan
dephilile said:When your lights dim is your motor running? If it is and the lights are dimming you probably need a bigger alternator. I don’t see how it would make your battery explode. It may shorten the life of the battery because when the lights dim you are interrupting its charge. It goes from being charged, to supplying power to your system for that big bass note, and then back to charging again.
