Now i am not looking to spent a huge amount of money here. But i do want more bang or boom for my buck. Now i have done a little research and found a sub and amp that seem fairly decent for the cost and their rated output. They are: SUB: Kenwood KFC-W3012 DVC $128.85 from ryda.com.au AMP: Kenwood KAC-M845 Car Amplifier for $188.85 from ryda.com.au Sorry if this is in the wrong section also. If anyone can tell me any other ideas on whether these are good value for money, if any others you know of are better and if those are cheaper elsewhere.. SUB: "General Features MAX POWER 1400W 12" Woofer with dual 4-ohm voice coils Urethane Surround Dragon Spider Design 2-Layer Voice Coil Design Dual Magnet Drive 8AWG Wire Capable Push Terminals Frequency Response: 35-300 Hz Sensitivity: 85 dB Mounting depth: 6-3/16" SPECIFICATIONS: Peak Input Power: 1400W Rated Input Power: 400W Impedance: 4 Ohms + 4 Ohms Sensitivity: 85dB Free-Air Resonance: 28Hz Frequency Response: 35Hz – 300Hz " AMP: "Maximum Power Output 720W Rated Power Output (14.4V ) 60W x 4 at 4ohms (20-20kHz 1.0% THD) 90W x 4 at 2ohms (1kHz 1.0% THD) 180W x2 at Bridged 4ohms (1kHz 1.0%THD) General Features Aluminum Die Cast Heat Sink Power MOS-FET Switching Power Supply Speaker Level Input Built-in Variable Low-pass Filter 50-200Hz (12dB/oct) Bch Built-in Fixed High-pass Filter 80Hz (12dB/oct) Ach 2ohms Load Capability Gold Plated Power & Speaker Terminal Cooling Fan Size: W 330.0mm x H 59.0mm x D 230.0mm " Thanks in advance. -Caleb
That amplifier wont power a sub, which I'm assuming you want it for. Well technically it could but it wouldn't be recommended.] Save yourself the $30 and get the SVC model sub, http://www.ryda.com.au/Kenwood-KFC-W3012-12-Subwoofer-Single-Voice-Co-p/kfcw3012.htm . And then get something like this for the amp, Shopping Secure - Car Audio Specialists - Ground Zero Iridium GZIA 2230HPX
