Injectors not priming or fuel pump not running and no spark at ignition leads are all separate things and generally not related. Ok, find the ignition module (transistor mounted on aluminium heatsink to the right of engine, on the body of car) and while trying to start engine, try hitting it with the handle of a larger screw driver moderately hard, see if you get any response..Yes mate I did all off that ther is a problem with the black end red wire from ecu ther is no 12v going to it I run a 12v igniting to it eng got feul pump end power at injectors end I engine light works to but I have no spark at coil end injectors not priming
Find aftermarket alarm/immobilizer box, and while trying to start car, try hitting that with handle of screw driver, see if it makes a difference...Yes ther is a aftermarket alarm on it
I have the fuel pump working just no spark from coil to dizzy have power at injectors but not priming I try my ignition module on my mates vr v8 end it worksInjectors not priming or fuel pump not running and no spark at ignition leads are all separate things and generally not related. Ok, find the ignition module (transistor mounted on aluminium heatsink to the right of engine, on the body of car) and while trying to start engine, try hitting it with the handle of a larger screw driver moderately hard, see if you get any response..
k mate I will can I disconnected see if that will workFind aftermarket alarm/immobilizer box, and while trying to start car, try hitting that with handle of screw driver, see if it makes a difference...
Should be above the brake pedals behind fuses (usually)
Just try hitting it a bit while trying to start engine, see if it makes any difference (before you go disconnecting it)O
The fuel pump might sound like it's working, but doesnt mean it's pumping fuel (it can still be faulty) but that does not explain why you have no sparks from ignition coil.. the two are not related at all... it could be your ignition coil that gone faulty or the HES inside the distributor has gone fauly.I have the fuel pump working just no spark from coil to dizzy have power at injectors but not priming I try my ignition module on my mates vr v8 end it works
You could try disconnecting one side of the ignition coil and use multimeter to measure resistance (in ohms) between the two sides of the coil.. as well as from one of the connections to where the HV comes out from the coil (but again, disconnect one side of the coil and remove the HV output plug) tell me what you find (if you have a multimeter)Ok
I will mate end thank you for yore help to
I try the coil to on my mates car end it works the dizzy is new end fuel pump is new to I check it end it's pumping fuelThe fuel pump might sound like it's working, but doesnt mean it's pumping fuel (it can still be faulty) but that does not explain why you have no sparks from ignition coil.. the two are not related at all... it could be your ignition coil that gone faulty or the HES inside the distributor has gone fauly.
