carcollector
- Aug 30, 2007
- 211
- 74
- 28
- Location
- Adelaide
- WM Caprice, VZ SS Crewman, ZB Calais V,VE CalaisV
I had a failed right front sensor, so I bought one from HSV-direct on ebay. I reset the system as per the instructions posted on this forum, and all is good. There are at least two different sensors, and they aren't interchangeable. The early ones have a metal stem, and the later ones have a rubber stem. This is visible from the outside of the rim.
A couple of tips too. The car learns the sensors in a specific order, starting from left front, then right front, right rear and left rear. As soon as one sensor fails, it will not continue with the learn procedure, so you don't know if any other sensors have failed. I had this problem in that because the right front had failed, I couldn't test the rear sensors. After a head scratch and a Whiskey, I thought I'd try mixing up the order of the testing. In the learn procedure, the car lights up the individual indicator corresponding to the tyre sensor it wants to learn next. Instead of going 'front left, front right, rear right, rear left, I relearned them as front left, then went and tested the rears, ignoring which indicator was lit. That way, I could see that both rears would learn OK, and it was only the front right that would fail.
The sensors learn by turning on the ignition, and pressing both the lock and unlock buttons on the remote. The horn should beep twice, and the left front indicator will illuminate. Then you have to either let air out of the front left, or put more air in, for around 8 seconds. When the tyre is learned, the horn will beep, and another indicator will illuminate. Follow the lit indicator around the car to learn all four. Letting a tyre down for 8 seconds leaves it pretty flat. As I have an air compressor at home, I found that bleeding the air out for 5 to 8 seconds, then immediately pumping air into the tyre would 'learn' quicker than just bleeding air out.
If you have a faulty sensor and replace it and successfully relearn all four, make sure that you reactivate the tyre pressure monitoring system (TPMS) on the dash options menu.
Cheers all
Love the car - it's awesome!
Cheers all
