Gouldinator1's Sv6
Gouldinator1
Strip Sack, Miller!
ACT
VZ Sv6
Been a while since the last update but plenty has been happening, most of it not car related :p
Car still runs and functions. Only minor maintenance, fluids and lubs changed etc.
The stuff I have been doing is garage and house related. So this is a pic dump of the stuff I've been building for the garage.
First a bookshelf for the corner.
Coat of clear paint.
Attached to the wall
Finished.
Then I re-purposed an old sink.
Gouldinator1
Strip Sack, Miller!
ACT
VZ Sv6
Part 2...
Then I built a big desk for the corner under the bookshelf.
I had a bunch of wood laying around and wood left over, so while building the desk I knocked up a wood trolley.
Otherwise I scored some Iwata spray guns for some work I am planning with the paint inside the car...but thats a future project.
Thanks for looking...
G1
Gouldinator1
Strip Sack, Miller!
ACT
VZ Sv6
I had some time, so using my new Iwata guns I redid the clear on the engine bay pieces and did the same on the interior. In there a did a few pieces completely from scratch.
It was interesting using quality guns instead of the Supercheap specials I had in the past. It took a bit of getting use to.
I've also been collecting black interior and leather pieces over the last few months. So I installed all those while I had the interior out.
New leather gear stick and handbrake, these I painted as well...
Redid all the locks...
And did the door handles, these I previously hadn't done.
Leather Console
Few pics of the black air con, mode and headlight switch...
Finished
The more pieces I did the better and more comfortable I got with these guns. The last piece of course came out the best.
G1
Gouldinator1
Strip Sack, Miller!
ACT
VZ Sv6
I thought I would throw these pictures up as they may be useful. I took a few while I switched the lights over. I was meant to take more but was busy doing the interior stuff.
Air Con
Window Switch
Console button (T/C in this case)
Mode Switch
Gouldinator1
Strip Sack, Miller!
ACT
VZ Sv6
Not much happening on the car at present, just maintenance.
Couple new tyres, wheel alignment, few new bushes for the front suspension and brakes replaced with new rotors and pads. Only change in set up, the front pads are now QFM Comp 9, rears still QFM A1RM.
Gouldinator1
Strip Sack, Miller!
ACT
VZ Sv6
I tried trimming the side console pieces with the black velour I had bought previously.
Here is the result:
It came out pretty good. I am going to try and do the same to the lower section of the glove box and the steering/fuse cover.
Sandman
Challenge Accepted
HQ VC VZ
The detail you've put into this car is amazing mate, keep it up.
