Gps 'switch on' with power windows
kubsnazx
adelaide
VZ Wagon '06
Looking for simple 'splice in' info for acquiring power for my gps unit whenever the power windows are active?
Presently, I have it connected to the pink wire found on the plug in the drivers side door jam (12 volt 'accessories on') but, i wish to change it cause I want to:idea3:
Has anyone got any gadgets switching on when windows are active? Or, (reason I want to do this) switching on when unlocking vehicle
morphix
Cardiff, NSW
2004 VZ SV6 5-Speed Auto
If you wire into the orange with yellow stripe that goes into the power steering switch, this is constant power 12v, which switches on when the car is unlocked and switches itself off after 10-15 minutes after the car is locked/left to sit.
Benboy
Hill River, SA
2007 SVZ Wagon
Connect the GPS to the 'cigarette lighter plug, (a.k.a. as an Accessory Plug) as when the ignition or Radio are switched on, the power is also sent to the said plug. I don't agree with splicing electronic appliances into others particularly since they are operated by a computer that enables only sufficient voltage to operate said appliance.
Tasmaniak
Not a valid input....
S.E. Melbourne
www.ranjinstallations.com.au
I agree with Benboy in part. I wouldn't take power from it directly, but I would have no trouble taking a feed from it to a relay with it's own seperate power supply.
morphix
Cardiff, NSW
Yeah a relay would be suggested rather than direct feed.
Sent from my Galaxy Nexus using Tapatalk 4
Tasmaniak
S.E. Melbourne
lol, mind you, some relays can pull 250mA and if it's JUST a GPS then it won't draw anymore than 500-1000mA in which case the power supply to the windows won't even notice...
But as a question to the OP...why?
kubsnazx
adelaide
VZ Wagon '06
Cause I like stuff that switches on with a remote
oska
vx custom 600RR
i've done it on my VX i'm sure it's the same with the VZ, my rear window child lock now acts as my antenna up/down
it also triggers it on unlock (up) and lock (down)
Tasmaniak
S.E. Melbourne
