So as I said a couple of weeks ago another piece of workshop equipment.
Life's got in the way so while I assembled /set up and bleed the hydraulic system have only just this arvo got to test it out.
It's a quick jack.
I would love a 4 post hoist, ( get storage as well then) . I had an engineer draw up a design ( he wasn't willing to get rid of the whole truss only the middle 1/3 ).
Would still therefore not get full height only missing out by about 130mm but not sure I want to trust proximity switches.
Also recon would cost with the hoist some where between $15k and $20k so yeah /nah.
Also thought about a mid rise scissor lift or the maxjax ( a portable mid rise 2 post ) but again the cost.
And so this ( it still not cheap =but you're crawling under a car on it ) I'd rather spend a few extra dollars and not end up flat as a pancake.
Going to make a 4 blocks to fit at the seem jacking points ( probably also buy quick jacks versions as well ).
It works a treat there are two safety bar lock heights the lower or mid rise you can still get a little movement if you try pushing/shacking the car but it's still less than if it was on jack stands.
With the max height it's locked in there is absolutely no movement it's rock solid.
https%3A//i.imgur.com/KShfoSd.jpg[/img]']
https%3A//i.imgur.com/numwVmE.jpg[/img]']
https%3A//i.imgur.com/jesTN4s.jpg[/img]']
Oh and
@losh1971 here's a pic of my venturi air vacuum.
