Grill blackout
Jack GS
Metro Detroit, US
2019 Buick Regal GS
Removing the entire piano black part of the center console isn't bad either. Doing so gives a pretty good look at the shifter bezel tabs and electrical connectors as well. I made a post with instructions and pictures on the Buick forum so I won't make duplicate posts, but here's the link (fixed, thanks @stooge):
Center Console Removal
P.S. When I took mine apart, I discovered one of the tabs on the shifter bezel was broken from the factory. Just be careful and take your time disassembling.
stooge
wa
Turbo Alpaca
Removing the entire piano black part of the center console isn't bad either. Doing so gives a pretty good look at the shifter bezel tabs and electrical connectors as well. I made a post with instructions and pictures on the Buick forum so I won't make duplicate posts, but here's the link:
your link does not work for me when clicked
PSISLE
Radelaide
VH SL/E, VF2 Director, ZB RS-V Wagon
Yes .mate I removed the bars from the grill a bit fiddly but not to hard I thought they were metal but they are plastic got them done gloss black clipped them back in looks great alters the front totally.
Can you share any tips on how you got the bars off the grill? I've been looking at it for a while now and I'cant figure out how to get them off without breaking something.
Cheers mate
John a
70
Cairns
Zb rsv
Cheers mate
Cheers mate
Hi mate lift the bonnet and remove the 7 press in clips holding the blank out in place remove the blank out you will see the the the small clips holding the bars in place push them down or up depending if top or bottom and push them out.you will have issues with the clips behind the air intake.small hands are a bonus.good luck .
Saffajosh
40
Auckland
2018 Commodore ZB RSV
Thanks for the info so far. Got the top plate off but that’s as far as I can get. There are white tabs and black tabs inside but none seem to want to give. Which ones should I be trying to move?
John a
70
Cairns
Zb rsv
Each bar has 4 clips they should be silver they are the ones you need to push out.be gentle as they are brittle
iZ_
41
Yallingup, WA
Calais ZB Tourer
What are you guys using to black it out?
I am a hater when it comes to chrome in car. ( Few exceptions in black cars)
So was planning to plastidip all the chrome bits, including the rails.
Have anyone tried this?
Cheers!
stooge
wa
Turbo Alpaca
Cheers!
i wrapped mine.
i found plastidip a bit crap especially once you get a stone chip it will begin to peel off with wind and rain on the front of the vehicle and it tends to fade from a nice black to a more of a dusty looking black.
plastidip can be touched up easier then wrapping and it is much easier to apply than wrap.
this is a pic of when i wrapped mine about 1 and a half years ago and it still looks pretty good aside from a couple of stone chips that are not really noticeable.
the chrome trim around the shifter needs to be wrapped too, it is horrible on sunny days.
i used a carbon fibre look wrap.
