Grommets
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by CHARGEDVT, Mar 17, 2008.
  1. CHARGEDVT
    CHARGEDVT Veni, Vidi, Vici
    Melbourne, Australia
    99' VTII S pack super6
    hey guys was gonna take the spoiler off my car so im gonna put some grommets as temporary until i decide if i like it enough to get the holes filled and sprayed. does any1 know where to get grommets and how much they roughly cost? also r they easy to put on? im guessing it would be a simple job.
    also is there any panel beaters out there that could give me an estimate on how much it would cost to get the holes sealed up and painted. i got quoted $500 by one place sounded a bit steep..... thanx
  2. sprocket
    sprocket New Member
    VT Exec SII
    $500 sounds about right, you'd need the holes filled, sanded and then the whole boot resprayed. Save yourself some money and spend a weekend sanding it!
  3. Rhino Racing
    Rhino Racing New Member
    vn/vp Speedway Street Sedan
    About $1 each from repco or autobarn
  4. r_i_d_a_h
    r_i_d_a_h New Member
    '97 VS Commodore + '98 E36
    i did a similar fill in job to my VS, check it out in the my ride section
    instead of the rubber grommets i used the christmas tree plugs, the plugs that hold the upholestry up.
    like stated above they are available from any automotive store
  5. CHARGEDVT
    beauty thanx fellas. now il have sumtin 2 do over the long w/e.
  6. CHARGEDVT
    also wanted to know if any1 out there knows if the process to taking the boot garnish off a VT and then putting it on another is easy/hard? thanx
  7. nicko
    sa
    75 cruiser ute
    hey mate, i just put a calais rear garnish into my vt and its easy to remove.
    there are 4 black clips with screws in them which are hidden under the metal of the boot frame but there are access holes for a screw driver (sit in your boot and you will see them. there are also 2 screws near the reverse lighting harness i think they are gold, then u will need to unplug the reverse lights and reverse lights can get photos up if you get stuck but u should be rite
    CHARGEDVT likes this.
