H&r z/u 94088
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Ash@DVS, Nov 9, 2014.
  1. Ash@DVS
    Ash@DVS New Member
    Geelong, Australia
    VE Wagon
    Hi all, I have a set of H&R springs, Z/U 94088 and have two questions -
    1/ It appears that they're suitable for a VE wagon, though I cant find anything that specifically says as much. I'd have thought that the wagon should have higher rear spring rate?
    2/ The specs say 40mm lower than stock. How much lower than the ride height for a VE SV6 wagon?
    Cheers!
  2. Ash@DVS
    Ash@DVS New Member
    Geelong, Australia
    VE Wagon
    Just wondering if anyone had any more information on this spring set or even if anyone on here has used this set?
  3. 1_johnboy
    1_johnboy Member
    east gippsland
    11` VE Omega
    taken from there website
    94088 Commodore VE Sedan except HSV, Export ohne Gutachten/without approval 2007> 40 94088 F + R
    94088-2 Commodore VE Ute except HSV, Export ohne Gutachten/without approval VA 15/HA 30 94088 F2 + R
    It does not mention wagon, But I would assume the wagon is the same as the ute (but thats on an assumption), also a different part number to what you have.
    40mm lower sounds like a Kin/lovell SL.
    My advise would be to contact the local distributor
    Jax Quickfit Geelong
    256 Moorabool Street Geelong VIC 3220
    PH: 03-5222-6255
  4. Ash@DVS
    Ash@DVS New Member
    Geelong, Australia
    VE Wagon
    Thanks mate, that's the same info that I was able to come across too.
    Appreciate the effort though.
    Cheers!
