Handbrake alarm vp calais
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by doms3, Aug 31, 2008.
  1. doms3
    doms3 Banned
    Vz
    I can't get the alarm to turn off have disconnected wire and still going BEEP???any Ideas ??:bang:
  2. VSIIBerlinaL67
    VSIIBerlinaL67 New Member
    VX SS M6
    which wire did you disconnect
  3. vnv8driver
    vnv8driver Banned
    Up your mum
    304 Calais
    is there 7 beeps in a row?? if so its definately the handbrake chime.
    First thing i would try is reconnecting whatever wire you took off and checking the tension of the handbrake cable.
    Next would be a faulty sensor, etc.
  4. ScoHar
    ScoHar Jizz in my pants
    CHCH, NZ
    VS Senator
    The wire you took off needs to be earthed for it to be "hand brake off"
  5. doms3
    doms3 Banned
    Vz
    Tried that no luck:bang:
  6. DanVN
    DanVN Cruizin' in style!
    Western Suburbs, Vic
    01 WH Statesman International 5.7L
    is the handbrake light on on the cluster?
    if not check the 4th connector on the bottom of the cluster the handbrake wire may be broken/pulled out
  7. doms3
    doms3 Banned
    Vz
    Light not on with handbrake,
  8. DanVN
    Definetly sounds like the 4th connector is the culprit then... Worst comes to worst pull the chime out of the cluster and be done with it :)
  9. doms3
    doms3 Banned
    Vz
    So just pull the cluster out and 4th connector in?
