Harmonic balancer
Pablito
Central Coast NSW
VF Redline, VE SS
Last time the car was dealer serviced and replaced under warranty the car was given back with the thermo fan connector unplugged causing it to nearly cook in my way to work the next day.
The dumb cnuts at Holden did the same thing to me when they replaced the balancer on my VE!
Ron Burgundy
NSW
VF II SS
If it goes again I will go with Powerbond balancer...
Strattos
2017 VFII SS
Hmm, pretty much bang on with my Ks. Will keep an eye on it.
Banjo79
VF SS Sportwagon
I've had two OEM balancers replaced in 175k/km's, though they really only seemed their best for 40-50k if not less. Finally have a Fluidampr in my hands, ready to go on sometime.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Are the factory balancers 'Made in Mexico' like the engines?
Or are they straight out of China?
Milo 6.0
46
perth
2013 vf ssv wagon/2009 fg xr6t(daily
My 2013 ssv wagon has only done 53k and the factory balancer was knackered,belt squeal when cold,wobbly.
Belt tensioner was also stuffed,not holding tension,pretty sad for only having done 50 thou I think.
Replaced with a powerbond unit and arp bolt,despite what others have said the arp bolt is not longer than stock,its identical in length.
07GTS
Australia
VEGTS BUILT BLOWN E85
there are 2 length arp bolts for the LS one suits something odd but if u dont know the part numbers u can accidentally get it, i actually got one off my mechanic that was sent the wrong size as they are good for getting the balancer started then use proper length after that
Milo 6.0
46
perth
First time ive heard about that but it makes sense.
The info I found on here said that the arp 234-2503 was longer than stock and made it so much easier to refit the new balancer,which would have been awesome if it were actually correct.
Why gm didn't just put a keyway on the crank nose like almost every other motor ever built has me stumped,stupidest idea ever.....
