have you seen this cam?
Discussion in 'General' started by BANKS, Dec 4, 2007.
  1. BANKS
    BANKS DW I'm a Spray Painter!
    Gold Coast QLD
    VZ SSZ Ute
  2. Torquen
    Torquen Boost FTW
    Perth, WA
    450+ HP FORD XR6T
    way 2 rough 4 my liken.
  3. f1tzy
    f1tzy New Member
    Brissy
    FG XR6T Ute manual
    yea doesnt really tickle my fancy. what are you after the cam for
  4. BANKS
    Gold Coast QLD
    VZ SSZ Ute
    i've listened to a few cams on ls1.com.au and youtube etc but none seem as balanced if that masks sense.
    All the other ones their idle is really random, this one doesnt.
    im planning on putting a harrop m122 blower on top but i want a better breathing engine before i do :)
  5. f1tzy
    f1tzy New Member
    Brissy
    FG XR6T Ute manual
    ahh. i was hoping u werent the type of tool who wants a big cam cause the lumpy idle is cool.
  6. BANKS
    Gold Coast QLD
    VZ SSZ Ute
    hahah yeah i dont want a massive idle out of it, want to benifits of a cam but not where the engine sounds like its going to explode. I just liked that one, bit loud put it seemed well balanced/tuned.
  7. Sabbath'
    Sabbath' Redblock Jesus
    80 Series// MK5 GTi//
  8. immortality
    Sth Auck, NZ
    even if you get the exact same cam it might not sound the same cause the entire engine effects the sound, right from the intake through to the tip on your exhaust. also a cam that works well for a n/a application is maybe not the best for use with a blower
  9. Dan355
    Dan355 Go THE SS's
    Street Legal 355ci VN SS - Daily: VP SS
    The stall converter on autos also has a big impact of the sound at idle. This sounds a little like my ss at idle but it sounds like hes running a stainless system. If your going to run a blower there will be no need for a cam that aggressive. All your boost will be wasted out the exhaust because of the valve overlap the cam will have. Just get a cam that has higher lift with minimal valve overlap. It may sound a little more lumpy but not like that.
  10. BANKS
    Gold Coast QLD
    VZ SSZ Ute
    so a mild cam is better for a blower application rather then a massive one?
  11. Dan355
    Dan355 Go THE SS's
    Yea thats right.
