Having a few problems trying to fit new rear rotors '99 VT
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Arrow88, Aug 25, 2012.
  1. Arrow88
    Arrow88 New Member
    South Australia
    VT Equipe
    I've just spent the whole day trying to replace rear rotors on the 1999 Series 1 VT Commodore, however they just won't fit!
    I purchased RDA standard rear commodore rotors, but they won't slide all the way onto the hub, I cannot fit the calipar bracket back on because the rotor isn't flush 100% its got about another 10mm gap.
    Any ideas? Does anyone know if the rotors between a series 1 and series 2 VT are different?
    Thanks,
    Arrow88.
  2. Sabbath'
    Sabbath' Redblock Jesus
    80 Series// MK5 GTi//
    Sit the new next to the old to see if there is any height difference for a start. How far out are the banksia shoes? Are they stopping the rotor from sliding in all the way?
  3. oska
    oska Active Member
    vx custom 600RR
    you might need to adjust the park brake shoes either loosen the cable or the brake shoes there is a wheel to adjust in the hub
  4. SID888
    SID888 New Member
    Northern Beaches, Sydney
    VX1 5.7L Berlina Wagon A4
    Same rotors for VT series 1 and 2. Handbrake is off? and yea check your handbrake shoes aren't out too far.
  5. Arrow88
    Arrow88 New Member
    South Australia
    VT Equipe
    Thanks for the quick replies guys. I think that park brake shoe might the problem. I had the handbrake off when i was doing the change over. Will check tomorrow.
