Ok well if you hav,nt got a manual for it this is what it says in mine
1)disconnect the negative battery terminal
2)release the clamp securing the air inlet hose to the throttle body & disconnect the hose
3)raise the front of the vehicle & support it on stands
4)remove the nuts securing the engine mounting to the crossmember & the engine bracket
5)using a suitable lifting tackle,raise the engine until the weight is taken off the engine mountings
6)when removing the left hand engine mounting proceed as follows
a)On automatic transmission models,remove the bolt securing the front of the starter motor to the engine bracket
b)On aircondition models,remove the airconditioner compressor retaining bolts & secure the compressor away from the engine
7)Remove the engine bracket retaining bolts raise the engine slightly & remove the engine bracket & engine mounting
now hope that helps but will be doing mine soon so tell ya how it goes as i dont have a lifting hoist & that is how it says to do it from the manual
