:bang: hey our vs ute got brocken into about 2 months ago and they bustad up the power window regulator and moter on the drivers side we got it fix and have had nothing but problems with it, it goes halfway down and then stops and now it wont go up or down, i have checked the fuses the wires going into the switches and thay are fine and i have striped the dash and all the wires are ok so i dont know where the problem is does anyone know. if thay can help out that will be great thanks.
First thing you need to do is remove the door trim and make sure the glass is in the side runners - if its been forced it has probably bent the side rails which hold the felt slides. Once you have the trim off you can also make sure that power is reaching the window motor. Good Luck.
