Having Trouble Removing Air Con Contorls HELP!!
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Dan_8933, Oct 21, 2007.
  1. Dan_8933
    Dan_8933 New Member
    Fraser
    Vy SS WAGON
    hey guys need help to remove the Air Con Controls the little rod i cant get undone any help????????????
  2. Fekason
    Fekason Fekason
    Penrith NSW
    It is a clip.
    I believe that it is a clip, which pivots from the bottom over the top of the plastic connector. Try to pull the top of the plastic connector up from the back and it should release. Then the control rod is just an interference fit, so pull it straight out.
  3. sganro
    sganro i speak before i think
    NQ
    yet another VS
    ^^^ yep thats right. Sometimes the clip can be tough to get off, so a flat head screw driver might be needed to help unclip it.
  4. Dan_8933
    Dan_8933 New Member
    Fraser
    Vy SS WAGON
    so u dont have to undo the screw near the firewall?
  5. SweetWagon
    SweetWagon booosted
    Springwood NSW
    VS Berlina Wagon Supercharged
  6. winton
    winton black+manual+19's=sex
    modbury
    vs SS II 5speed vx gts 19's
    mines a screw.
  7. markovr
    markovr Well-Known Member
    northside brisbane
    07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
    That clip often breaks..I just undo the phillips head screw that the arm pivots on and pull it out as a unit with the plastic arm and rod still attached
