hazard lights flashing while driving!
M
Macca_75
Guest
Hi guys,
I've got what I think is a strange problem, my VS II's hazard lights will flash automatically while driving. Nothing seems to be causing the lights to flash, usually its when I'm diriving in a straight line. It's bizarre. Any thoughts on what the problem is likely to be and how much its likely to cost to repair?
Thanks,
Macca.
WiLo
Wollongong
VS exec
do you press the button and they turn on:p
id say the switch or relay is faulty
kopper69
VRII Acclaim
Except indicators wont work if you remove the hazard switch. Infact removing the hazard switch my disable the flashing system altogether, meaning they wont flash, but that wont solve the problem. Swap relay first.
=Calais v8=
Holden Tech Apprentice
37
S/E Melbourne
VSII 5.0L Calais, 13b ae71
weird, but at least you're warning other drivers your car has a problem ;)
RAD1
2001 VX commodore
My one doing the same, its a VX Commodore. its flashing randomly and when ever i open my boot or door it will flash 9 or 10 times and then will stay lit up for 5 secs.
mpower
that can be the flasher unit.
1985VK
Australia
VK SL
The car may be infected with corona virus... You may need to burn it... just kidding...
axemurderer101
Albany
forums.justcommodores.com.au
VY SS
Do you have an aftermarket alarm or immobiliser in your car?
RAD1
2001 VX commodore
Nope i don't have an after market stuff. Indicator switch, hazard switch and relay all were alright. however the solution was to disconnect the battery and keep it for 5 mins and than put it back together, here u go! all going good. I think its resetting the BCM by doing the battery thingy . It worked for me. Hope it helps others.
