Hazard Lights VT Executive
wheelbarrowvt
Malmsbury, VIC
VT executive wagon 2002
I bought a 2001 VT wagon 2nd hand off a dealer. I have had a string of issues which are being worked out. But one issue I can't figure out. Indicators work fine. Hazards don't. Now I'm not sure but when I lock and the car by remote the hazards don't flash, should they?
What could the problem be? I just need some direction before I rip the dash out and break things I don't need to break.
Oh, and my heater control. Cold is cold 3 clicks clockwise it's Sahara Mid-Summer. What up with that?
mint
55
n
VE
The hazard flasher is probably a separate unit to the indicators. Try cleaning & replugging it, then maybe replacing it.
Heater? Most common problem is that it doesn't work?!?
Killr6
tutut
Hervey Bay QLD
BA XR6T
no the hazard and indicators are the same unit, if your hazard light wiring etc is ####ed, your indicators wont work.
have you looked at the fuse? under the steering wheel to see if its blown?
axemurderer101
Albany
forums.justcommodores.com.au
VY SS
there are 2 fuses for hazards and indicators, so make sure the hazard fuse isnt blown.
heater problem could be a faulty heater tap under the bonnet
wheelbarrowvt
Malmsbury, VIC
Sweet, I'll check out the fuse tomorrow. I checked the fuses under the bonnet, but hey who knew there was a fuse under the steering wheel. Not me.
I'll inspect the heater tap, after Googling what a heater tap is.
wheelbarrowvt
Malmsbury, VIC
Ok. direct under the steering wheel there is "the thing that looks like it could take a fuse" but there are no fuses in it. I tried the small blade fuses (10amp), no dice, it's too big. What kind of fuse should it be?
axemurderer101
Albany
VY SS
i hope your not talking about the diagnostic plug lol, you have to pull the large panel under the steering wheel down, then inside you will see all the fuses
boomnvn
SOLDER, NO CRIMP.
39
Croydon
www.KungFuKustoms.com
VT Exec S1 V6
yeah, the fuse panel cover meets at the bottom of the steering column, and there will be a little gap you can stick ur finger in to pry it off. its on hinges so it'll swing down and there's the fuse panel under there.
