HDT air cleaner PCV
VK85SL
33
Doncaster
1985 VK Commodore SL
Just wanting some advice around how I go about connecting the hoses on the VK HDT air cleaner. Currently I have the standard 4 barrel air cleaner which has a hose coming from the driver side rocker cover ( I believe this is the pcv valve) to the base of carby and there is another one from the rear of passenger side rocker cover to the back of the standard air cleaner.
The HDT one I want to replace it with is a different setup though (refer to photos attached) as the hose connections are at different part of the base. My question is whether I can have the PCV connect straight to the HDT air cleaner and run the longer hose from the base of carby to the back of the passenger side rocker cover (or will this not work because HDT VK's had a different rocker cover?). As at the moment its the opposite of this with my standard setup as they came like that from factory.
