HDT VK SS Group A/3 replica
hdt_027
Brock 05
Bathurst, NSw
www.youtube.com
VK SL
Model: HDT VK SS Group A/3 (replica)
Colour: Formula Blue
Bodykit: Group A Front Bar, Grill, Wing – Group 3 Rear Bar, Side Skirts, Bonnet Scoop
Engine Type: 308 Black Motor
Engine Mods: 308 stroked to 355ci, Block Cleaned, Aligned and Bored 60thou`, Brock B Cast Ported heads with Big Valves, Polished 308 Strip Master Manifold, 650cfm DP Holley ProStreet Carburetor, IPR Race Alloy Rocker Covers, Hi-energy Sump, Alloy Radiator and Oil Cooler, K&N Air Filter, 1.5ratio Yella Terra Rockers, Hydraulic Lifters, Crane Hydraulic Camshaft, Hyperneumatic Pistons, Double Row Timing Chain, Race Series Harmonic Balancer, Holley Fuel Pump, Eagle 9mm Race Leads, All new Chrome Nuts and Bolts
Power: 450hp
Exhaust: 1 5/8inch Genie Headers into Dual 2.5inch System with X Pipe then through Lukey Mufflers before being dumped before Diff - Fake Tail Pipe Welded at Rear
Gearbox: T5 5 speed Manual, Heavy Duty Clutch, Custom Short Shifter
Diff: Salisbury Diff, 4.44 gears, LSD
Brakes: VT Twin Pot Calipers on 296mm Slotted Rotors up Front, Standard VK Discs on rear
Suspension: Pedders Shocks with Lowered Springs, Adjustable Pan Hard Rod
Wheels/Tyres: Advanti Alpha 18x8inch Wheels, 235/40 series Federal Semi Slicks
Interior: Blue Velour Calais Seats, Blue Looped Carpet, New Black Rooflining, Black Painted Dash and Centre Console with New Gear and Handbrake Boot and new MDF Arm Rest with padded vinyl covering, MOMO Steering Wheel with MOMO Race Pedals. Autometer Pro Shift Lite and D-Pic G-force Gauge
Other Mods: Battery Removed to Boot, Overflow Tanks under both driver and passenger engine bay in front of tyres. Fuses Removed to under dash. Brant twin Immobilizer and alarm system, 5 digit Keypad on dash, Power Steering. Engine Heater system deleted, new electric heater with switch installed. Custom dash spot housing missile switches and Autometer Gauge, DVD Player custom fitted into front air vents, Boot Mounted Fire Extinguisher
Stereo: Alpine 7inch DVD Headunit, 4channel Signat Amplifier, 3way Signat system in the rear consisting of 5 1/4inch midrange with tweeter in door with 6x9inch Mid-woofer in rear parcel shelf, 2way Signat system up front running 5 1/4inch Midrange with tweeter in door. Fusion 8inch Subwoofer in Bass tube with built in amp. Ipod Connection
vkwalks39
NUCKING FUTS
Stawell Vic
VK V8 / VH V8 / VR V8
man thats awesome, I love it cheers Jason
Reaper
Tells it like it is.
RG Z71 Colorado, 120 Prado , VDJ200, Vantage
Congratulations on what looks like an awesome car.
Reaper
