commodoredave
vt II v6, no turbo or scharge
symptoms
NO oil going into coolant
NO coolant going into oil
No obvious loss of oil
No overheating
minor coolant loss ( say, 125ml per month)
lower manifold intake gaskets recently replaced with no leaks
White smoke on cold start on cold early morning out of tailpipe.
Rough ( misfiring) on startup but settles down when warm. Struggles ( chugs) up hills but does not overheat.
sucking sound around the vacuum air intake area.
Would a cylinder pressure test confirm a blown gasket? What other signs might be worth considering?
symptoms
No overheating
