head lights question
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by immortality, Dec 29, 2006.
  1. immortality
    Sth Auck, NZ
    the H4 globes incorporate both the headlight and highbeam lights but when you push the highbeam switch forward to keep em on only the 2 highbeam only lights stay on (H3 globes)and the headlight go off but when you pull the highbeam switch forward(momentary) it uses the highbeam lights in the H4 globes (normal headlights). is there any way you can keep both sets of highbeam lights on?
  2. 05 VZ SS
    05 VZ SS New Member
    VZ SS 5.7 M6 Silver
    Check fuse in the engine bay for the lights....Happened to me a while back....
  3. Fu Manchu
    Fu Manchu Well-Known Member
    WA
    Slug powered VZ, a VE Calais & your mum.
    Also make sure the relays are working correctly. toot the horn and if it toots, pull the horn relay out and plug it into the headlight relay plugs and see if there maybe a faulty relay.
  4. immortality
    Sth Auck, NZ
    i'll give both a try. did it a while ago but it hasn't botthered me much cause i never really drive this car at night. just thought it was odd that it used different globes depending on which way uou move the highbeam switch
