losh1971
- Jan 17, 2010
- 22,606
- 22,361
- 113
- Location
- North Tas
- VE Series I SS Ute
I think some head work will benefit low and top end. Given it probably has some miles on it the valves would benefit from a valve grind plus something shaved off to also help get some more compression. I am considering a cam with stock lift but some extra duration. But that will depend on if I do the work or the garage does. I want the mech to disco the balance shaft like I requested but he failed to do during the overhaul. I reckon even just stopping the engine having to turn it will actually increase HP, even if only marginal. On a race bike we take off any gear that the engine spins, plus we reduce any weight that we can that the engine needs to drive, even dropping down a chain thickness to help HP at the wheel. Not sure if same applies to cars but on bikes any weight the engine is not driving is equivalent to 100x that in actual weight. so essentially 10 grams off the crank is equivalent to a kilo on the bike frame, IIRC.
