losh1971
- Jan 17, 2010
- 22,590
- 22,328
- 113
- Location
- North Tas
- VE Series I SS Ute
If you only want to make power before 4,000rpm do not bother with the heads. Just add boost.
Toying with the head flow and cam duration will just move the torque curve forward in the rev range.
You could get a small centrifugal supercharger for not much add a real time tuning connector and 2 bar map sensor and get it tuned.
I am considering a small SC but I am also mindful the valve springs have an unknown mileage on them as does the seats. I'm keen to reco the heads regardless and have a valve seat reshape, plus compression bump. As for porting I am undecided as i need to talk this over with the machinist. He may just suggest smoothing out the bumps. My plan is to have a good base to go boost if I decide too. I have new chain and gears, new crank bearings all round. So figure the next step is gaining some comp. But then need to decide how much as yeah too much might cause problems if I do indeed decide I want boost.
On a side note I have what I believe is some lifter noise, possibly from bleed as it goes away after 50 - 60 seconds. So yeah it's mani off anyway so not much more to slip heads off, I'm thinking.
My skill level is enough to fit new heads but ensuring I have optimum mani port alignment is probably something I will help with. I may be able to find someone to help check the latter but I may not be able to either.
But yeah as DD no use having it go like a bastard once I hit 4k, I'd only get done for hooning...
