Header Difference
Discussion in 'VF Holden Commodore (2013 - 2017)' started by Cava91, Apr 28, 2017.
  1. monstar
    monstar Naturally as-pirated
    depths of Hays Inlet
    Peugeot 207 GTi
    I can't say one street header type is better than the other, that would be just useless opinion. Rather with either of the basic street type using data in the OP in this thread I can definitely point to one design specification as a better fit for purpose based on stock LS3 performance specification data (5700 RPM peak HP).
    Info in that post provides complete details to achieve certain results on our LS3 in a street car with mufflers and a tailpipe:
    Low to Mid-Range RPM Torque and HP (4-2-1 or 4-1)
    Low to Mid-Range Torque and Hi RPM HP (4-2-1 or 4-1)
    Mid-Range TQ to Higher RPM Horsepower (4-1)
    Higher RPM Horsepower, possible TQ loss (4-2-1 or 4-1)
    Haha very close:D
    FWIW I don't race around and make noise, love the low down torque, so if I had a near stock LS3 the perfect full system would be:
    Headers
    Type: 180º reflected pressure wave headers, coated
    Initial Dia: 1 3/4" at block
    Primary Length: 32" long
    Final Accelerator: 2.25" at merge​
    Collector
    Type: Divergent Megaphone
    Length: 19" from merge
    Final Dia.: 3"
    Volume: >47 cubic inch before cat substrate​
    Cats
    Type: 3" 200 cpi Steel Barrel
    In/Out: 2.5", integral to collector (riser sawn-off)​
    Mid-Pipe
    Type: 2.5" stainless​
    Balancer
    Type: 2.5" pressed clamshell X
    Axle-Back
    Type: 2.25" stainless
    Resonators: 9" hot dogs​
    Mufflers
    Bi-modals or
    Sports muffler with helmholtz piping​
    SnowDoggyDogg likes this.
  2. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    VF Redline Sedan - A6 Spitfire MSE...
  3. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
  4. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
  5. panhead
    panhead Well-Known Member
    NSW Central Coast
    Cars
    Thanks mate, very informative videos.
    Geoff6666, PSISLE and 426Cuda like this.
  6. monstar
    Peugeot 207 GTi
    Yep @426Cuda you are quite eloquent and well spoken for a country fella ;)
    PSISLE likes this.
  7. SnowDoggyDogg
    SnowDoggyDogg 2ltr? = Only milk & juice
    Goldie
    Gen F GTS
    Well where the fook can we get these 180 headers? I NEED that sound!
  8. monstar
    Peugeot 207 GTi
    This is how 180° headers sound tuned to an LS3, in our car:
    Designed for our car daily Street duty, Low to Mid-Range Torque and Hi RPM HP on petrol at 6200 RPM peak. All systems made to order.
    Headers, wideband sensors, harness, megaphones, cats, x-pipe and full custom road tune as a tunkey solution for $4k fitted.
    SnowDoggyDogg, 426Cuda and PSISLE like this.
  9. PSISLE
    PSISLE Well-Known Member
    Radelaide
    VH SL/E, VY2 l67 calais, ve2 l77 Calaisv wagz
    Is that the voice of the mysterious creature referred to as cuda, known to frequent the area around Wagga Wagga?
    426Cuda likes this.
  10. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    Umm, thanks Monstar, I think? Taking the Akubra off helps attenuate the bush twang. Lol.
    Anyway, hopefully it's of some assistance to anyone looking to do this upgrade. Your vids and pics certainly helped me at the time. ;)
    PSISLE and monstar like this.
  11. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    Nah mate, that was a stand in. Gotta keep the mystery alive.
  12. MY17DIR
    MY17DIR Active Member
    Gods Country, NSW
    MY17 LE Director....
    Great vids thanks cuda! Perfect sound in my opinion and just what im after :cool:
    426Cuda likes this.
  13. shadow69
    shadow69 New Member
    south is.new zealand
    magnum on order
    wow that sounds great. what set up is this? i have a magnum on order and drove my 1st v8 ute this weekend (maloo with 340kw) and both wife and i now cant wait for delivery. pretty committed to a ful exhaust,cai and a tune straight away.
    monstar likes this.
  14. Super Coach
    Super Coach GTS, S, CV8Z, SSVR
    HT GTS, VN S PAK, VS S PAK, CV8Z, VF2 SSVR, MSE
    Cant wait for that vuy to fit it to his motorsport and have a listen. Was he using hsv cats or different brand? If differentvwhat brand were they?
  15. monstar
    Peugeot 207 GTi
    That is the Crossbones 180° reflected headers with megaphones, cats, x-pipe with 2.5" catback, HSV bi-modals. It is an advanced exhaust system, not for the feint hearted.
    Installed and engine tuned correctly, the ignition firing order remains same however exhaust pulses are re-ordered by crossing over pipes from one bank to the other so as to order exhaust pulses sequentially. In simple terms this turns an exhaust pipe into a siphon that draws in fresh charge from the intake during valve overlap in a process called inertial supercharging.
    Same primary efficiency advantage as a flat plane crank (Ferrari, GT350) without the bolt-snapping secondary vibrations. In other words although it may sound better the primary purpose of its engineering is better performance throughout the LS3 operating range.
    shadow69, 426Cuda and SnowDoggyDogg like this.
  16. lmoengnr
    lmoengnr Well-Known Member
    Sunbury Vic.
    MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
    AKA 'sonic ramcharging'.
    monstar likes this.
  17. Super Coach
    so after reading all these posts, went out to the garage and got out my HSV exhaust that I bought to put on my Redline which never happened as I bought a Motorsport so waiting for that to arrive and fit it on. I bought 340kW GenF2 Clubsport headers and cats. The diam at the end of the cats is 2.5" and the diam of the holes for the heads where they bolt up the exhaust on the manifold measure outside diam 2.5" the inside of the headers is 2".
    I then bought a centre section off a GenF2 GTS and the pipes are 2.5" in diam and on one end I have a flat flange and the other end if just a round fitting with a clamp.
  18. Super Coach
    which thread was it that someone posted a photo of the Holden LS3 and the HSV LS3 exhaust systems together? Cant find the photo now.
  19. Mike__
    Mike__ Active Member
    Vf2ssv
    Thanks for the detailed videos cuda car sounds great.
    Mike
    426Cuda likes this.
  20. PSISLE
    Radelaide
    The plot thickens......
    426Cuda and Cava91 like this.
