Headlight Clip
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by newvsowner, Apr 19, 2011.
  1. newvsowner
    newvsowner New Member
    JG Cruze
    Dear [INSERT NAME OF READER HERE],
    I was replacing my driver's side headlight bulb, and the clip, and now i can't for the life of me figure out which way it went so that it hinges out and clips back. At the moment I have it wedged so that it stays there. Does anyone have a picture or description of how it goes in.
    Cheers.
  2. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    Don't understand why you would have removed the clip (spring retainer) to replace the globe - it's not necessary.
  3. VS_Pete
    look at the other side
  4. newvsowner
    JG Cruze
    i have looked, they seem different? but thanks for the diagram!!
  5. Maffmak
    Maffmak New Member
    Newcastle
    Ve
    any luck?
    Iv had exactly the same problem.. was going off directions from another thread on here, loosened one screw on each side of the headlights and released the clip.. Now I cant get it back in for the life of me haha.
  6. Wozza
    Wozza Well-Known Member
    VR_GS commodore
    the spring retainer clip will only lock in if the bulb is seated fully in, at the correct orientation (the horizontal tang on the rear of the globe) go's to the top and of the right type
  7. duckbill01
    duckbill01 New Member
    Perth, WA
    VE Berlina 2007
    Bump :)
    My first post because I've got a problem...
    I was trying to get the orientation right of my headlight by taking it in and out to adjust it. Then the spring clip broke off.
    Any advice on how to fix this? Do I need to take the air filter out and see if I can fix the clip back in? Thanks.
  8. Patrick123
    Patrick123 New Member
    Ve omega
    Does anyone know where I can get a replacement ve omega commodore headlight bulb retainer ?
  9. Sabbath'
    Sabbath' Redblock Jesus
    80 Series// MK5 GTi//
    Weird place to ask since this is a VS Section...but anyway. Go to a wrecker.
    losh1971 likes this.
